2.93 MPG Increase
Old Mar 23, 2006 | 04:07 PM
  #31
460Kirk's Avatar
460Kirk
Originally Posted by d_stange
Gas mileage bla bla bla. People these are trucks. There made to haul or pull or both. If you're worryed about mileage buy a cheap little car. I use my trucks on the farm and maybe on the weekends and once in a while to work. Otherwise i drive my car. 22-25 is a lot better than the 10 i get with my truck.
I use a different vehicle for back and forth to work. Since it's not a "work" truck I enjoy using it for many recreational activities. It's kind of an ongoing project of mine (and I suspect others who subscribe to this "Ford Truck Enthusiasts" forum ) to improve upon its performance. That may include modifying the engine for more HP, torque or better drivability and gas mileage, upgrading the suspension, appearance add ons, the list goes on and on.
Some may actually enjoy and have fun sharing experience and ideas in this process. I can understand your situ, but don't be raining on our parade.
Old Mar 23, 2006 | 07:10 PM
  #32
topfisherman's Avatar
topfisherman
Originally Posted by vman
I wanted to try that fan kit but theres no way I'm shelling out $500.
If you want to go a cheaper route, you can swap in an electric fan from a Taurus. You can pick those up at any junkyard for $20-40. After that you only need to get the stuff to hook it up and a higher output alternator. So depending on if you get a new or used alternator, you are looking at around $100 for the whole setup.
Old Mar 23, 2006 | 08:02 PM
  #33
oldfordtrucksrule's Avatar
oldfordtrucksrule
i dont think u really need any fan for highway driving. we drove a 93 150 auto with NO radiator fan 30plus miles to the landfill towing a 16 ft 2 axel trailer loaded with junk (long story) and it ran fine temp wise, until we had to stop and wait in line. im thinkin about takin mine off and seeing what happens.
Old Mar 23, 2006 | 08:33 PM
  #34
topfisherman
That is true, on highway the fan doesn't need to be running, this is where electric fans give you the best MPGs because they wont run then. When you are doing stop/go driving, driving at slow speeds, and idling is when you need the fan turning.
Old Mar 23, 2006 | 09:10 PM
  #35
vman's Avatar
vman
That's pretty much the idea I had.Take everything off my taurus and use it if it doesn't pass emissions testing.
Old Mar 24, 2006 | 01:01 PM
  #36
d_stange's Avatar
d_stange
didn't mean to rain on any parades. Just making a point. I try to squeze every drop per gallon i can to but i'm also on a pretty tight budget. I didn't mean to make anybody angry this is a great site with lots of info and it has helped me out on some things alot. Sorry to anybody who i may have made ege.
Old Mar 24, 2006 | 01:33 PM
  #37
jcp123's Avatar
jcp123
I'm intrigued by the Taurus e-fan idea. Generally, what all do you need to do that swap? How is it with towing (I occasionally tow a car and a few times a year our riding mower or go kart on a 1400# trailer)?
What about aftermarket throttle bodies for a 302 (5.0)? Worth it?
Old Mar 24, 2006 | 01:41 PM
  #38
skrappy's Avatar
skrappy
take the electric fan with thermostat probe out of a taurus and put it in
Old Mar 24, 2006 | 01:42 PM
  #39
skrappy's Avatar
skrappy
all you have to do is either wire it up to a toggle switch or get one that has the probe and it will turn itself on when it needs to, it works just fine, just remember when you take the other fan out you still need the belt goin around that pully for your water pump
Old Mar 24, 2006 | 02:16 PM
  #40
quicklook2's Avatar
quicklook2
get the fan out of a 3.8 taurus, that is the one that moves the most air.
Old Mar 24, 2006 | 03:27 PM
  #41
topfisherman
Yea, that one is the best, if I remember right it is a two speed also so it doesn't draw as much on start-up. You will need wires, a fan controller, a temp. sensor, and you will need to upgrade your alternator to at least a 3G.
oblivionnewtonjohn
24
Feb 12, 2015 06:34 PM
500TPmech
1997 - 2003 F150
Jan 1, 2012 09:28 PM
Wathen1955
1997 - 2003 F150
28
Jun 16, 2010 02:26 PM
mattebury
6.4L Power Stroke Diesel
Sep 3, 2009 04:25 PM
CPerry
Modular V8 (4.6L, 5.4L)
18
Oct 2, 2003 08:22 PM
