Stuck in 4x4 low
Old Mar 16, 2006 | 11:38 PM
aboehler's Avatar
aboehler
Stuck in 4x4 low
I just bought this 1989 F150 super cab/short bed and had it in 2H until i decided to test the 4x4.
First there was a clunk everytime the wheel turned over.
Any clue???
Then the worst part. I took it out of 4x4 because I didn't like the sound and after about a mile the transmission/transfer case was grinding everytime I idled to a stop. Then it lost power completely.(engine still ran). So i shifted around the transfer case and now it's stuck in 4x4 LO.
Really Frustrating to drive at a top sped of about 40mph at 4500 rpm.
Need HELP!!!!
Need the truck to work
Old Mar 17, 2006 | 04:38 AM
aurgathor's Avatar
aurgathor
I assume you drove it on a good pavement in 4x4, which is a big no-no. Lift all 4 tires off the ground, and try to shift it out of 4x4 then.
Old Mar 17, 2006 | 12:07 PM
fordraceboy's Avatar
fordraceboy
is it a pushbutton or a lever? if it's a lever, try backing up and shifting it out gear while backing up.... thats a good trick for the old fords that had mismatched gear ratios.. i.e. 4.09 front gears and 4.10 rears...
Old Mar 17, 2006 | 07:36 PM
aboehler's Avatar
aboehler
Well backing it up didn't work, i don't think running it up off all wheels will either.
but thanks for the help, please give me more suggestions becasue i really don't want totake out the TC to fix it.
Meanwhile I'll try jacking it up off the ground.
