dropped suspension
Old Mar 16, 2006 | 09:44 PM
FirstTry's Avatar
FirstTry
dropped suspension
this is something i feel that belongs here not somwhere else
i wnat to drop my front suspension(65 V8 2Wd) do i merely have to swap the coil springs? or do i have to reposition/replace the I-beams. if i freshen the rear back to stock will it look goofy?thanks everyone
Old Mar 17, 2006 | 07:46 AM
truckfarmer's Avatar
truckfarmer
To do it correctly, you will need to use dropped I-beams from either DJM or AIM Industries. If you only cut or swap springs, you will never be able to get the front end aligned again.
To lower the rearend, look at both of those vendors for longer shackles and/or lowered spring mounts.
