Pcv
Old Mar 16, 2006 | 08:13 PM
brownstraightsix's Avatar
brownstraightsix
Pcv
Hey guys.
I'm building my 84 300 (offy,holley,reman head, hedders, etc...)
I noticed that built 300 sixes usually dont have PCV valves, they just seem to breathe.
What does that do more? Is it better to put a breather cap instead of the pcv valve or should i keep the pcv valve on?
Thanks
Old Mar 17, 2006 | 03:50 AM
srercrcr's Avatar
srercrcr
If you have a visual emissions inspection, you won't pass without the PCV.
If you allow crankcase fumes to escape, we all get to breathe them, and return to the 70s when the pollution burned our eyes.
Old Mar 17, 2006 | 03:54 AM
ford390gashog's Avatar
ford390gashog
the PCV system is a good system to keep. It prevents the combustion byproducts from building up in the crankcase and causing moisture to mix with the acidic byproducts and forming sludge and deposits. Even old cars had a road draft tube to prevent such problems. a simple breather will not cut it.
Old Sep 5, 2010 | 08:00 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
anyone running a worn 300 that has blowby that overcomes the pcv so they had to add a road draft tube? And happened to notice the steel line coming from the fuel tank to charcoal canister was routed well and hooked a line from valve cover where it used to go into intake to this steel tube and ran a rubber hose from the tube at the frame near the right rear tire just off the ground to deal with the excessive blowby?
lol
4rdnut
Dec 22, 2010 03:28 PM
harryvil
Escape & Escape Hybrid
Sep 18, 2007 07:08 AM
bci101tractors
May 19, 2006 10:12 PM
hopk2517
Apr 20, 2006 07:20 AM
ewellman
Oct 23, 2004 10:12 PM
