injector pump problems
Old Mar 16, 2006 | 04:56 PM
Dieseladdict's Avatar
Dieseladdict
I have a 1993 Ford F250 7.3 non turbo diesel IDI. My injector pump went bad, and my friend took of the pump and the housing it bolts to off. I know thats not how we were supposed to do that in the first place. Now I have everything bolted together, but not on the truck because how do I know how to line up the two gears... PLease help
Old Mar 16, 2006 | 06:38 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I think I found your answer in my Haynes teck book. Look for two "Y" marks on the camshaft gear and injection pump drive gear. they should be together. Then you should put the housing on. Then the IP fits into a alignment dowel.
Old Mar 16, 2006 | 07:49 PM
Dieseladdict
Thank you very much this has been a big problem for me today.
Old Mar 16, 2006 | 08:06 PM
bigredtruckmi
Veteran: Navy
Glad to be of help..
Old Mar 16, 2006 | 08:27 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The Y in the cam gear will be hard to see.
The Y on the cam gear should be at a valley in the gear teeth.
The Y on the IP drive gear should be by a tooth.
The teeth tops should be dyed on both sides of the groove the IP drive gear tooth will go between.
You will probably have to disassemble the IP assembly to see down inside to set the gear.
1994 F250: 351, C6
15
Feb 16, 2009 02:25 PM
92F3507.3LIDI
Oct 28, 2007 02:24 PM
whitefordaward
86
Feb 8, 2007 06:17 PM
f100guy
Jun 22, 2006 08:28 AM
