Sponsored by: Real Truck
Door Sensor Problem
Old Mar 16, 2006 | 03:42 PM
bigbrad96's Avatar
bigbrad96
Door Sensor Problem
I have a 2002 F-250 Heavy Duty 4x4 four door powerstroke diesel. Last week I noticed my door ajar light stays on even when I have made sure all doors are shut. This sensor affects my automatic light sensor and my keychain remote is disabled at this time. I was wondering if anyone had any suggestions on how to fix the problem.
Old Mar 16, 2006 | 04:46 PM
guzzle92's Avatar
guzzle92
If your door switches were sticking, your fobs should still work so I'm thinking VSM. Take a look at this thread.
https://www.ford-trucks.com/forums/s...&highlight=vsm
Old Mar 16, 2006 | 04:51 PM
bigbrad96's Avatar
bigbrad96
I took a look at the thread and I have many of the same things wrong with mine. Is it hard to change out the VSM or do most take it to the dealer to fix?
Old Mar 16, 2006 | 04:59 PM
guzzle92's Avatar
guzzle92
You can change it out yourself but it will have to go into the dealer to get the old one scanned with it still connected. They will then flash the new one with the scanned code. I saved a few bucks in labor and put the new one in and left the old one on the trans hump still connected. You have to remove the lower portion of the center dash to gain access.
Old Mar 16, 2006 | 05:59 PM
ColtM4's Avatar
ColtM4
Or it could be a bad instrument cluster as in my case.
Old Mar 16, 2006 | 06:08 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
Hey guzzle, its alittle tricky but I got to mine with out taking the panel off. Probably because I could'nt figure out how!!! But with a little patience and determination I got the 10mm deep-well socket in there.$140 for the VSM and $145 for flashing(which I thought was excessive). Thank the Diesel Gods I did the labor myself, they really would have raped me!!!
Old Mar 17, 2006 | 05:21 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
For a start, welcome to the site bigbrad96!!!
Thread moved to Super Duty forum
Old Mar 17, 2006 | 06:43 AM
missouguy's Avatar
missouguy
I have the same truck. No problems yet, but you guys have me holding my breath.
Frank
Old Mar 17, 2006 | 08:50 AM
Munkey's Avatar
Munkey
Hmm, have you tried spraying down the latches with WD-40?
I think guzzle92 might have already discounted this, but heck, it's worth a try!
Lots of users have reported door ajar warnings, interior lights staying on, etc, and the problem is a dirty door latch. Spray 'er down and see if that works?
Old Mar 17, 2006 | 02:09 PM
qikgts's Avatar
qikgts
Sounds like what happened to me...
https://www.ford-trucks.com/forums/s...d.php?t=467859
I wish my fix was as easy as a door latch problem.
Old Mar 26, 2006 | 07:51 PM
bigbrad96's Avatar
bigbrad96
Smile
I just wanted to let everyone know that I took my truck in to the dealer and the problem was my Vehicle Security Module (VSM). Thanks for the help.
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
TampaDave
May 5, 2010 05:04 AM
calibob
1997 - 2003 F150
Dec 27, 2008 01:47 PM
macuserbb
Feb 22, 2003 10:17 PM
