ABS code
Old Mar 16, 2006 | 11:12 AM
Freek's Avatar
Freek
ABS code
Hello,
I'm Freek from the Netherlands Europe and I own a 1995 F150 XLT 5,8
My ABS light flashes; 15 short flashes and 1 long flash.
Cruise control doesn't work since the ABS flashes.
While the engine is running I can't go from P(ark) to D.
Only when I start it in (N)eutral I can switch to D(rive)
Does anyone have an idea ?
Thanks in advance,
Freek
Old Mar 20, 2006 | 03:35 PM
95X15's Avatar
95X15
If you retrieved ABS codes by disconnecting the ABS Black connector and grounded the black/orange wire with the ignition on, the 16 code means the abs is working OK per 95 manual.
Is the red brake light on? this can be emergency brake engaged or a bad float switch in the master cylinder ( or low fluid level in MC). Check fuses 13, 15 and 17.
Also check to be sure that there is no fluid in the Cruise control brake pressure switch mounted on top of the master cylinder at front - this is subject to recall and needs a fusible link harness installed to prevent fire related problems when switch leaks.
The inability to shift out of Park is associated with the shift lock solenoid located at lower end of steering column - the work around is to do what you describe and is in the owner's manual, I believe. Normally when you put your foot on the brake the solenoid releases the shift lock to allow the shift lever to move. Check fuses 13 and 18.
Good luck.
Old Mar 21, 2006 | 01:08 PM
Freek's Avatar
Freek
Thanks for the answer.
I've solved the problem.
The trailer-brakelight wire was damaged, and the fuse melted.
I thought I'd checked all the fuses, but I must have missed this one.
the4by4freek
Dec 14, 2014 10:26 PM
the4by4freek
27
Dec 4, 2012 10:48 PM
Ford Freek
Jan 9, 2005 07:08 PM
the4by4freek
16
Nov 26, 2004 08:51 AM
pocobueno
Feb 2, 2004 07:09 PM
