...I know that the rear door's power window switch plates simply pop off.
The driver's side seems reluctant to do so. Should this still pull off?
I'm trying to see if I can simply change the switches to get auto down on all four windows. I know in the Cobra, I had to install a module....but the Ex has the switch with the detent.
