driveshafts
Old Jan 18, 2001 | 10:18 PM
79ford's Avatar
79ford
driveshafts
Old Jan 19, 2001 | 02:05 PM
ford429cu's Avatar
ford429cu
driveshafts
i was wondering if a rear driveshaft from a 77 f250 4x4 np435/np205 dana 60 rear will fit a 78 f150 4x4 c6/np205 with 9 inch rear?
jeff
Old Jan 19, 2001 | 02:09 PM
ericsbadf150's Avatar
ericsbadf150
driveshafts
I highly douby it, the trannies are different lengths, but measure to find out. Eric
Old Jan 19, 2001 | 06:38 PM
trouble's Avatar
trouble
driveshafts
If you have a drivline shop close they can make it fit your truck . Therfore you will have a heavier drivline if thats what your after.
Trouble
Old Jan 19, 2001 | 07:03 PM
alpo23's Avatar
alpo23
driveshafts
Don't forget that the 9" and the Dana 60 may not have the same size yokes. The width and cap diameter may not be the same. there is some range of adaptability availible from spicer for the u-joints but you'll have to check.
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205
And a '68 Bronco 289 v8 , NP435 , Dana 20
