6 Volt Gauges
Old Mar 14, 2006 | 03:14 PM
mikeiz's Avatar
mikeiz
6 Volt Gauges
Any Hint On Where To Buy Some 6 Volt Gauges Amp. & Volt Thanks Mike
Old Mar 14, 2006 | 05:19 PM
Franklin2's Avatar
Franklin2
Buy one of these invertors and then get normal 12 volt guages. Replace the guage lighting with 6 volt bulbs. This invertor can be found at www.jcwhitney.com Type number zx813905r in the search box on JCWhitney's site.
Old Mar 14, 2006 | 05:28 PM
mikeiz's Avatar
mikeiz
thanks for the quick reply. how many gauges can be hooked to inverter
Old Mar 14, 2006 | 05:33 PM
mikeiz's Avatar
mikeiz
looked it up @j.c.whitney will it work on pos. ground system thanks, mike
Franklin2's Avatar
Franklin2
The $69.99 one has an output of 1.5 amps. I don't know what kind of guages you are looking at, but any type of guage doesn't draw much. So you could put a lot of them on there. They have a more expensive unit with a higher output, but I don't think you are going to need it with just gauges. The illumintation lighting in the gauges will draw a lot more than the guage will. But you can hopefully change the bulbs to 6v and run them directly.
gt40racing
Sep 7, 2009 10:53 AM
scott0531
Aug 6, 2008 01:17 AM
reed1951
Jun 24, 2007 11:52 AM
dylan1952
Feb 6, 2007 11:18 PM
cbass
Aug 1, 1999 07:54 PM
