I have an '02 Off Road XLT Ranger, it's been "the other woman" for a little over year now and it may cause the real one to leave if I don't stop paying attention to it. LOL! Now it has the usual brush scrubs and dings from gravel associated with hunting and fishing and I can deal with that, because I caused it, I'll re-paint and get the same grafics put on.
BUT I have to draw a line when someone else does it! I can only guess that some kids got ahold of packing tape or some other strong adhesive tape and decided that the seames of my fuel cap and doors were not water tight and taped them. My problem is that I got most of the backing off(not all) and it all left a tacky white residue. I have purchaced some "Goo Gone" but the wheather in my area hasn't permitted me to try it out yet.
Question, Is it safe to use a razor blade (Box Cutter) to remove the rest of the film and will "Goo Gone" remove the residue?
Techniques, products and help appreciated!
PK
Pretty much all of the auto stores have adhesive remover, which does a fine job. 3m makes it, I believe. You'll want to buff afterwards as the adhesive remover sometimes dulls the clearcoat.
You can use a single-edged razor blade (not a box cutter), but you really need to have a steady hand. I used to remove pinstripes that way all the time when i was younger, but I wouldn't attempt it now with carpal tunnel.
go go rubbing alcohol, i use it at the shop to take off pinstrips all the time, and any other imprefections from things that are sticky, lol well hope you get it off.
