Hello, i have 2001 FORD TRUCK EXPLORER SPORT 4WD
6 Cylinders 245 E 4.0L EFI SOHC out of no where no power put on obd2 came up system too lean (bank1) rough idel, chang plugs clean filter all fluids good truck starts r up idel some what good no poping missing pull out good but ony gos 20 mph with foot to the floor going only 1 block smells like real hot gage not showing over heating put back on obd2 system too lean (bank1) gone shows 0 with c, ev, o, oh, e flashing meaning could be one of these what do you think Thank Don
oh ya, would like to clean the idle passages and the idle speed motor.
but need but need help tracking them down
First of all - this is the F-150 thread, you should post this in the Exploror thread. Second of all, use punctuation (properly), it is very hard to decipher what you wrote. From what I could gather, your Explorer is having an issue with power and will not get above 20mph. The on-board computer is throwing an error code that signifies that bank 1 is running lean. Now, I just happened to own a 2000 Epxlorer Sport with the SOHC and it had a very similar problem. I believe there was a gasket somewhere on the backside of the engine (I can't remember exactly what it was) that blew and caused my problems. If I remember correctly, there was a recall and the dealership fixed the truck with no questions. This was at least 3 years ago, so I may be mistaken about the recall. But I do remember that it was a common issue with this particular engine (SOHC) and the dealership knew exactly what to do.
