Pressure Washers-Who Has One and What's Your Opinion?
#46
got a 5hp briggs, 2500 psi, probably 8 years old, and i havent found anything that it wont cut off, have taken paint off of trucks, but for some things i have to back off a little. if you dont have one, you cant go wrong with gettin one, id say get it, and get one bigger than you think that you will ever need, and you will be happy for a long time, and personally id recommend gas, and not electric, bout all those are good for is cleanin cars at best!
#47
I bought a Karcher at BJ's. Had problems after about 60 mins of working to clean a pool deck. Called Karcher. They said that model had a lot of problems and they sent me a newer model. It works great. I do not wash vehicles with it unless I use the low pressure nozzle. The high Pressure nozzle will remove paint. Especially on my old MH. Using a pressure washer to clean is a tedious, long process. It can only do about a 4 inch swath at a time. A driveway is sure bigger than 4 inches.
#50
Originally Posted by billsco
Does anyone know if pressure washers have to be stored in heated quarters during cold winter months? Or is there a way to winterize them against freezing?
Sam
#51
Originally Posted by sdetweil
Mine, just bought from Harbour Freight, has winterizing instructions.. I live in Texas, so I don't need em..
Sam
Sam
My wife is pushing to buy one. I see one more piston engine to maintain, and one more to winterize, and one more to put who knows where. In Minnesota it would be considered out of season for at least five months. Have the guys who have posted here think they've used their power washer more than they envisioned, or less?
#52
#53
to winterize, go buy some RV anti-freeze, get a old garden hose, cut just long enough to reach the bottom of the antifreeze jug.. then squeeze the wand trigger, slowly pulling the starter rope, {make sure the engine switch is OFF} keep pulling till you see anti-freeze come out the wand.**for electric's just turn the switch on and off** disconnect the hose, and duct tape or cap off the inlet....next add some STP fuel stabilizer if it gas powered, be sure to top off gas, if its a metal tank so it wont rust.and turn the fuel switch off, and run it for a minute to empty the fuel bowl/carb.
one important note be sure to change the pump oil at least once a season, better to do it now, so that way you won't have to worry about it next year when you go to use it again.....hope this helps
#54
I suppose you skipped through it, then. Were there ten or more pages of winterizing steps, do you remember?
If only Ford would build pressure washers!
#55
Mine is electric.
Sam
#56
I just got a Craftsman Easy Carry 3.5 hp 2000psi and wish I had gotten one years ago! I've used it to wash my truck, lean my porches, decks, and vinyl siding. It's very usefull and easy to move around. I also bought it at a discount becuse the box had been opened.
Great tool to have!
crbourret
Great tool to have!
crbourret
#57
I just bought one, too, and how the heck did I live without one of these things? I've got a lot of that white resin furniture on the deck, that stuff that no chemical will clean. A few passes of the pressure wand and PRESTO! it looks like new. Also great for cleaning the deck and the patio. The part that amazes me is that I don't use any detergent- just the pressure cleans everything! Everyone should have one of these.
#58
Sam
#59
