wierd overheating problem
Old Mar 20, 2006 | 06:59 AM
Ford_for_Brains's Avatar
Ford_for_Brains
Originally Posted by Dr.Reese
In all my years Have
I ever Heard of A Vechile w/ a blown head gasket run all day w/o overheating ok come on look nothing this man is saing leads to a head gasket like i said prevously back flush your system fix the vac leak and go from there that is the least evasive and most helpful thing you can do for your truck a vac leak alone can make it over heat, a sticky T-stat, he]] it can be a no. of things you have trubble shot it with us start simple you can spend all day and a weeks worth of money tring to fix the smallest of problems an ounce of prevention is worth a pound of cure!
A vac, leak cant cause overheating for one, and I've seen several head gaskets and crack heads that didnt nessecarily cause overheating, but rather some oil in the cooling system, some antifreeze in the oil, or in the case of the wifes truck that was doing this same thing, the gasket was weak allowing engine compression to pass into the cooling system when the engine speeds increased, but at an idle the problem would appear to go away.
As far as you stating he indiactes nothing that would point to a headgasket, I'm guessing you think antifreeze evaporates on a regular basis from a sealed system then.
as far as being "least invasive", pressure checking the cooling system is about as simple as it gets, twist off the radiator cap, screw on the pressure tester, pump it up and let it sit for a couple minutes.....sure sounds less invasive, and infact cheaper (it doesnt cost a penny to do, and most autozones or any other auto parts store will loan the tool), and if it indeed looses preasure, saves going thru the process of elimination by swaping parts that are fine to begin with, hence saving time and money.
theres also another test that detects CO2 (which would be present if theres combustion in the system), it costs about $20 at most parts stores, and is a very accurate chemical test.....the downside is that it only indicates if theres CO2 in the system, if theres any other leak besides engine combustion being forced into the cooling system, this test will not find it.
Old Mar 20, 2006 | 10:56 AM
Dr.Reese's Avatar
Dr.Reese
i kknow what bubble testing is and back flushing your system and pressurising it with water is an easy way to check for external leaks plus it never hurts to have a clean cooling system that is why it is the least invasive not to say that a leak down test is wrong but if you don't have the tool you can work with what you have and onceyou have clean pure water in the system it is faiorly noticable when you have oil in your cooling system.
Old Mar 20, 2006 | 03:34 PM
bohiaa's Avatar
bohiaa
I just fixed my 93 from doing this...
It's the heater core...mine was clogged....
There cheap dont flush them just replace
Old Mar 22, 2006 | 01:18 AM
Dr.Reese's Avatar
Dr.Reese
if you are having over heating problems nomatter what the over all cause is it is 30 k preventive maintnace you ever heard the saying an ounce of prevention is worth a pound of cure most car drivers have the mentality tht if it ant broke don't fix but what happens when your timing belt snaps on a OHC you could bend all of you valves is tha a good enough analgy for you
Old Mar 22, 2006 | 01:24 AM
Dr.Reese's Avatar
Dr.Reese
Cool take it or leave it
I told the man to back flush his system doing that alone can unclog a dirty heater core because you are sending fresh water through you heater core backwards hins the term back flush!!!
Old Mar 22, 2006 | 05:21 AM
Ford_for_Brains
damn reese, switch to decaff already. We get it, your opinion is we're all morons and youre not...alright already
Old Mar 22, 2006 | 10:16 PM
Dr.Reese's Avatar
Dr.Reese
I was not calling ignorant i made that coment to bohiaa y spend 30 bucks when you can flush it for 5
Old Apr 1, 2006 | 10:54 PM
bohiaa's Avatar
bohiaa
I think you kind of Contradicted your self here didn't ya.
But what do I know?
Old Apr 2, 2006 | 07:24 AM
stresssolutions's Avatar
stresssolutions
Did I read somewhere that you guys wouldn't change the Tstat and water pump, hoses and belt if doing a head gasket? Makes sense to me to change that stuff while you're in there and got it apart...
moosey78
Feb 16, 2014 09:36 AM
97flairside
24
Feb 11, 2005 07:11 AM
f-250boy
Dec 15, 2003 12:15 AM
blackbird
Apr 11, 2003 08:53 PM
EvilAerostar
Aerostar
Nov 27, 2001 07:50 AM
