Hey everyone I just wanted to know what would be the best amp to get for these Sub woofers there is 2 of them so:
12" VERY High Performance Subwoofers
800-watts MAX Power Handling
400-watts R.M.S. Power Handling
45oz Strontium Magnet
Freq Response: 30Hz - 1kHz
Efficiency: 91.1dB
PHat Foam Surround
Poly-Coated 2 Layer Non Pressed Non Transfer KM3 Coated-Cone for Virtually No Cone Distortion
2" four Layer Black Aluminum Voice Coil
Nice Dual 4 Ohm Voice Coils
2 Ohm or 8 Ohm Operation Each one
The Mounting Dimensions: Depth; 5 1/4" Hole; 10 7/8" Diameter; 12 1/2"
Nice Lug Lock Terminals
That would be the one you want. dual 4 ohm voice coils wires in parallel = 2 ohm; two 2 ohm loads wired in series = 4 ohm load. That amp puts out 800W X 1 @ 4 ohms, perfect for those subs.
