t case leaking?
Old Mar 13, 2006 | 10:13 PM
busted knuckle's Avatar
busted knuckle
t case leaking?
my 205 case is leaking from the front yoke i replaced the seal but it still leaks. the front yoke has a small grove cut into where previous owner ran it without the seal for so long. is there a way to fix it without dropping 70 bucks for a new yoke? i want to replace both yokes ir i have to replace the front bc i suspect the same in the rear and replace all the seals this summer. the case makes no strange sounds and works fine just leaks out very Quickly.
Old Mar 14, 2006 | 10:52 AM
1975Ford's Avatar
1975Ford
Try the auto parts store and ask for a replacement sleeve for the yoke.
Old Mar 14, 2006 | 05:45 PM
busted knuckle
thanks ill try it.
Jesse
Old Mar 14, 2006 | 06:14 PM
1975Ford's Avatar
1975Ford
busted knuckle, try U-joint Inc in Albuquerque, New Mexico. They carry everything spicer. They will even give you the specification on your yoke if needed.
-Buck-
Old Mar 15, 2006 | 09:25 PM
busted knuckle
thanks buck thats a cool gallery and a nice clean lookin truck. thanks for the help.
