Need help lls not working
Old Mar 13, 2006 | 06:10 PM
orange_x_crush's Avatar
orange_x_crush
I have a 2000 Navigator with the lls. The check suspension dash light is on. The rear axle sags. I replaced the compressor, compressor relay (twice), and replaced a level sensor that the electric board looked brown, replaced all fuses (all looked good but was worth a try). I took it to a Lincoln shop and they wanted to replace the module. Talked to another shop and they said modules rarely if never go bad. I have the relay harness jumpered with a switch to manually turn the compressor on. Compressor runs fine, and will lift the rear end. The rear axle bags stay inflated for a day or two before I have to air up again, slow leak I guess. Is there a way to test the relay, or is something else out. I tried disconnecting the battery to reset the system. I'm lost.
Old Mar 13, 2006 | 07:17 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
To find out where to ask this question....click on the link below.
https://www.ford-trucks.com/forums/s...88#post3272088
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
ol-blu
New Member Introductions
May 19, 2006 08:06 AM
Ken King
Mar 19, 2006 06:06 PM
Geno'sWoes
Mar 6, 2006 05:57 AM
cmdata
Feb 25, 2006 07:15 AM
recap
Jan 20, 2006 05:33 PM
