i have a 98 f150,4.6.this forum helped me troubleshoot the low flow egr problem,the egr plenum ports must be plugged so bad,the engine idles fine with the egr valve removed,am going to remove it and clean tommorrow,thanks again for your help,john g
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page. JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
