exporer runs rough at idle and is missing with a load on the engine. i pulled the codes for koeo and i get 335 code (pcm determined elecltrical circuit for crankshaft position sensor "a". and the run code is 326 knock sensor 1 is out of range. i checked the position sensor (crankshaft) and i'm getting 1.16 volts while backprobing the sensor to ground, with eng running and rpm varing the volts flucuate about .02(1.14-1.118) not sure if this is normal my manual does not specify?? i checked the fuses all fine, also checked the wiring diagram and i do not see a knock sensor , not sure if there is one for this vehicel. any in put would be great. thanks
