2005 Expy Headlite Removal ?
Old Mar 13, 2006 | 01:47 PM
Hotshoe's Avatar
Hotshoe
So how do I get the headlite out? I removed the 2 top bolts but no movement. I bought some Silverstars and there is got to be an easy way , but I dont see it ?
Old Mar 13, 2006 | 05:57 PM
AF Mezkin's Avatar
AF Mezkin
If I remember right you have to remove the middle bolt and then you just pull out, they have some pins that make it hard to pull, a little force is required. I would put some type of protection around the opening to protect your paint.
Old Mar 14, 2006 | 08:26 AM
Hotshoe's Avatar
Hotshoe
So , off with the 2 on top in the radiator support and where is the one in the middle ? from underneath ? Behind ? Or I must be blind !
Old Mar 15, 2006 | 10:50 AM
mhilton777's Avatar
mhilton777
Trailering
If you look directly behind the headlight housing, you will see the middle bolt recessed about 6 inches. You'll need a ratchet extension to get to it. Once you pull that out, the headlight will pull directly out, but it will take a little force as previously mentioned.
Matt
aclan
2009 - 2014 F150
Aug 31, 2016 11:07 PM
scaryskippy
May 14, 2015 11:43 PM
'50'sFever
20
Mar 25, 2015 09:31 PM
tbugher62
Nov 26, 2013 10:08 AM
