Hood Kit
Old Mar 13, 2006 | 11:34 AM
Oldie53's Avatar
Oldie53
Thumbs down Hood Kit
I'm thinking of getting a hood kit,For my !953 F-100. I installed new hinges and that was a waste of money. Can any one tell me about them???
Oldie53
Old Mar 13, 2006 | 12:48 PM
jeff5683's Avatar
jeff5683
If you don't want the new hinges I'll take them off your hands
Old Mar 13, 2006 | 05:28 PM
papabills54's Avatar
papabills54
I put on a new front hood tilt kit from john's f100 and it worked out pretty well. took about 2 hours and a couple of small cuts with a die grinder. most of the time was adjusting .
Old Mar 14, 2006 | 01:34 PM
Oldie53's Avatar
Oldie53
If I get a hood kit, I'll let you know
Old Mar 14, 2006 | 03:19 PM
AXracer's Avatar
AXracer
New hinges should work right, likely an adjustment problem, try moving the latch striker plate forward a bit (might be difficult to get to move, mark it's location on the latch panel and remove bolts completely, then reinstall further forwards based on your marks.
Old Mar 15, 2006 | 08:21 AM
Oldie53's Avatar
Oldie53
It's the springs
that will not hold up my hood
Old Mar 15, 2006 | 08:56 AM
fatfenders56's Avatar
fatfenders56
didn't work when they were new, they don't work now
Old Mar 15, 2006 | 11:49 AM
fordgo's Avatar
fordgo
sounds like the springs are not tight enough with the hood open you might have to preload them tighter to have the hood stay up they have a tool to do it but i did it with vise grips and i dont recommend that
__________________
Experience is the name everyone gives to their mistakes.— Oscar Wilde
gee ooh
Old Mar 15, 2006 | 02:45 PM
Jag Red 54's Avatar
Jag Red 54
After you try adjusting the springs and they whap the #%&* out of you, get the tilt forward hood. I suggest getting the model that looks like mine instead of the billet units. Good luck, Jag
