Adding Heated Side Mirrors???
Old Mar 13, 2006 | 10:55 AM
oregonn8v's Avatar
oregonn8v
I was wondering how dificult it is to swap out my side mirrors (w/intengrated turn signals) for ones that are also heated? Also, where would I get some? I have a '97 Expedition EB.
Thanks,
Eric
Old Mar 13, 2006 | 11:47 AM
KyEdExpedition's Avatar
KyEdExpedition
I can't say for sure if this is 100% plug-and play on an Expedition, but I added heated side mirrors to my Taurus, and they were plug-and-play...no additional wiring needed. I just got the new mirrors and plugged them right in.
Old Mar 13, 2006 | 12:28 PM
oregonn8v's Avatar
oregonn8v
Did you have to install a button or new control panel inside to be able to turn the heating function on/off?
Eric
Old Mar 13, 2006 | 12:37 PM
KyEdExpedition
No, the heated mirrors are turned on when the defrost button is selected on the climate control.
Old Mar 13, 2006 | 08:07 PM
lakesidebluexpy's Avatar
lakesidebluexpy
oregon-
on our first gen, early body style expy's, you either have heat or turn signal- not both.
sorry......lakeside ('97 eb expy)
Old Mar 13, 2006 | 09:03 PM
oregonn8v's Avatar
oregonn8v
If I have turn signals can I change it out for heat or is my only option turn signals?
Old Mar 15, 2006 | 08:11 AM
fourfeathers's Avatar
fourfeathers
I bought heated aftermarket mirrors for a non-turn signal setup. Can I wire them to use the heat function? How?
Old Mar 15, 2006 | 07:35 PM
Lauda's Avatar
Lauda
Nostalgia:
I modified my two standard mirrors in a old Ford Granada (Europe) without heated mirrors. A simple solution: Open carefully the mirror cover, and then glue or fastening ad lib a socket for a 21 - 45Watt buld ore something like that. Don't use halogen bulbs, they will maybe be to hot for the mirror plastic cover. Make two cables +/- from the socket, and then connect this to a switch with 12 volt supply (don't forget to use a fuse on the system). The heating from the bulbs, will be enough to melt away ice and snow. Simply, and very cheap.
N.B
Mount the buld as nearest you can on the backside of mirrors, and observe the distance from all plastic.
Old Mar 15, 2006 | 07:48 PM
aagitch's Avatar
aagitch
What year Taurus do you have. I've been wanting to add heated mirrors to mine, thanks.
expguy121
Jul 1, 2012 10:03 AM
HeathJohnson
Mar 24, 2010 02:09 PM
silly34
Mar 2, 2005 07:30 AM
tmdvtpike
Aug 26, 2004 12:11 PM
eric3t
May 20, 2002 06:31 AM
