99 or 99.5
Old Mar 13, 2006 | 10:05 AM
newblade's Avatar
newblade
99 or 99.5
What is the difference and how can you tell? Is one better than the other?
Thanks
Old Mar 13, 2006 | 11:51 AM
barebackjake's Avatar
barebackjake
the 99.5 has the larger intakes, makes a little more pwr over the 99 big diff you can see is the 3" intake over the 2-3/8"
if it was me i would get a 99.5
Old Mar 13, 2006 | 09:17 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Thread moved to 99-03 PSD forum.
Old Mar 13, 2006 | 09:25 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
walking up to the truck, you can tell the difference, the early 99 has the V8 powerstroke badge on the front quarterpanel, where the current V8 and V10 gas labels are. from 99.5-2003, the PSD badge is on the door.
Old Mar 13, 2006 | 09:33 PM
clux's Avatar
clux
No, there were early 99 with the door badge.
Check your build date on the factory sticker on your door jamb. If it is before 12-08-98, then it is an early.
Old Mar 13, 2006 | 09:45 PM
Turbo_Whistler's Avatar
Turbo_Whistler
After 12-08-98 you will have the late 99 motor and cosmetic stuff. But it is still possible to have some random early 99 items. My truck is built feb-1999 and I have early 1999 front U-Bolts and the taller early 1999 blocks in the rear. My truck was being built in the cross over period I guess.
Old Mar 13, 2006 | 10:29 PM
The Blue Pearl's Avatar
The Blue Pearl
Don't know about that
So I just ran out to the truck to read the door. The Date 05 98.
Pearl has 710,000 klm original motor and tranny.
So the 99's are ok too I would say.
Old Mar 14, 2006 | 12:07 AM
LONEPINERON's Avatar
LONEPINERON
Also the braks changed in 3-15-99 to 105 mm from 95mm on rotors. Hey they all run great and atleast you still get forged rods.
Also what is the conversion to miles on "PEARL" LPR
Old Mar 14, 2006 | 07:39 AM
barebackjake
i have no problems with the early 99's but if i had to choose i want more HP.....
didnt know about the bigger brakes....thanks!!
Old Mar 14, 2006 | 08:57 AM
cnd999's Avatar
cnd999
Mine has a build date 11/98 and has door badges and newer style air filter which all came stock I think. Many "early" 99s had the air filter drawing fresh air from the fender well. Anyway I removed the filter housing to do the Kwik filter mod so it really doesn`t matter, I`m just giving a bit more info. I think the injectors and the high pressure oil pump are slightly less flow also in early 99s.
If I had heard all these differences before I bought my truck combined with the mileage they probably would have scared me away. I made a great choice in buying this Ford and I was never sorry. I actually felt mine had a bit more power in stock form then my friend`s 03, but maybe I`m biased! Turbo housing and wheel are slightly smaller also. Hope this helps you make your decision, Dan ;;;;;;;;;;;;Forged rods are icing on the cake.
Old Mar 14, 2006 | 12:48 PM
Medic 66's Avatar
Medic 66
Door badges.......first thing that comes to mind. BUT....I have a 99A and just got the door badges from EBAY.
Old Mar 14, 2006 | 06:15 PM
cangim's Avatar
cangim
If it were me, I'd get a 99 built after 3/1/99. Mine is a pre-99, no problems, but aftermarket parts and items are more readily available for later 99' models.
Old Mar 14, 2006 | 11:15 PM
The Blue Pearl
on my early 99 there is no door badge. Its on the left front fender.
jgilrfr
Aug 4, 2015 03:32 PM
twm011
Apr 22, 2015 06:41 PM
cowboybootlegger
Ford Truck Parts for Sale
Feb 3, 2015 08:54 PM
Shernius
1997 - 2003 F150
Oct 30, 2009 07:54 AM
