Sponsored by: Real Truck
Front drive axle
Old Mar 12, 2006 | 04:33 PM
rplatt7's Avatar
rplatt7
Front drive axle
Just took apart the passenger side bearing/hub. I am sure the seal was bad as there was rust all in the hub and the auto locking hub was shot. Also axel shaft itself is rusted all the way to the diferential. My question is should I be worried about the rust on the axle and also how forgiving is the amount of rust on the drive axle?
Old Mar 12, 2006 | 07:38 PM
tjbeggs's Avatar
tjbeggs
the rust on the axle into the axle housing is ok. the differential is sealed near the carrier housing so it would be normal for the axle shaft to rust there but the hub should not have rusted
Old Mar 13, 2006 | 05:29 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved to the Super Duty forum
