Codes Codes Codes
Old Jan 31, 2001 | 04:27 AM
f100custompurple's Avatar
f100custompurple
Codes Codes Codes
I have a 77f100 custom pickup with an axle code of 47, it is a 9 inch, thanks whd for that answer, my question is..given this code can someone tell me what the gear ratio is? also i want to make sure this is a 360 FE block, i found out i could look on the passenger side between the two bolts and as well on the numbers in the heads, so what numbers am i looking for? Thanks, f100
Old Jan 31, 2001 | 12:56 PM
beartracks's Avatar
beartracks
Codes Codes Codes
I believe almost all 1/2 tons of this era had the 9" Ford. If it hasn't been messed with there should be a metal tag under one of the pumpkin bolts that will give the ratio. i.e. 3.50 and a "P" if it's traction lock.
1977 Ford F-100
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jan 31, 2001 | 02:21 PM
BB's Avatar
BB
Codes Codes Codes
