dana 44 or 60?
It's probably the 44, but if it is the snowfighter???? then it would probably be the 60. If you can, get the tag number off of it and post up here and somebody will let you know what it is.
Or, just look on your vin on your drivers side door and decode it using this link:
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Easiest way to tell is to look at the top of the knuckles on the axle. If the knuckles have caps on them (driver's side would have a steering arm connected to the cap) with 4 bolts in a square/rectangular pattern then it's a D60. If not then you have the D44 which is what usually came in those trucks.
roscoe
Sep 29, 2000 01:37 AM
