4.6 swap
Old Mar 12, 2006 | 11:36 AM
jimdandy's Avatar
jimdandy
4.6 swap
I have a 4.6, 280 hp, out of a 96 Mark VIII. I plan on swapping this engine into my 96 f150 in the future. Has anyone here done this or something similar. jim d
Old Mar 14, 2006 | 01:18 PM
ncranchero's Avatar
ncranchero
Thumbs up
I want to see it!!
I wanted a Mark 4.6L DOHC in my Ranchero but won't fit without cutting her up. You should be able to use the Mark harness and ECU without much trouble especially if you have the 4R70W auto trans.
Old Mar 14, 2006 | 04:50 PM
jimdandy's Avatar
jimdandy
Trans in the truck is a 5 speed, and I didn't get the trans for the Mark VIII. I have a 94 T-bird parts car, and was thinking I might use that trans, but now I am not sure that it will work. I need to research a little more. Mark VIII's are pleantiful around here, so a trans won't be a problem. I did get the computer with the engine. But, I have a few more miles left in my 5.0, so I'm in no hurry. I want to have everything I need in place when I start the swap. jim d
Old Mar 19, 2006 | 06:43 PM
the_fordvan's Avatar
the_fordvan
If you find a usable 5-speed that a truck or van can use to couple with the 4.6DOHC (kenne bell anyone? > ) put up some trans model numbers as well as what you need to convert from automatic (i hate my auto)
Old Mar 19, 2006 | 07:16 PM
jimdandy's Avatar
jimdandy
Is the bell housing on the DOHC different from the SOHC? A Mustang or later F150 manual should work if they are the same. Like I say, I'm just now learning the DOHC. jim d
Old Mar 19, 2006 | 09:30 PM
the_fordvan
The bell housings from 4.6sohc to 4.6dohc will be exactly the same, if I'm not mistaken. The difference is in the heads, cams and intake bits. I'd like to swap a new, more efficient 4.6 SOHC or DOHC into my 85 Econoline. The Mustang or F150 manuals should work fine, since the 'stang and the F150 share a fair number of parts.
What about the F150 lightning motor?
CharlieMaxwell
Modular V8 (4.6L, 5.4L)
Apr 21, 2019 10:20 AM
bigbaddorsey
Jan 24, 2015 07:15 PM
hitechredneck
1997 - 2003 F150
Apr 12, 2007 04:24 PM
mikepink
May 22, 2000 06:32 PM
1997 - 2003 F150
Sep 28, 1999 04:18 PM
