Help with ID'ing my axle.
Hi again,
I have a question about my axle that maybe someone can point me in the right direction for identifying it. I pulled off my bed this afternoon which made it much easier to read the tag on the axle, although it did not say FORD on it anywhere. I know its a FORD since the bolt pattern is. I'm really just trying to get the ratio.
Anyways the tag reads
EV AA1 7CB
75 9 718A
I looked up a TON of sites for ID'ing tags but everyone starts with a W.. If I read it wrong or it was just that dirty it might have been WAA1 but i doubt it. Any ideas?
JoE
EV AA1 7CB
75 9 718A
JoE
Originally Posted by JoeSwing78
Hi again, . . . I'm really just trying to get the ratio. . . .
JoE
JoE
If it has a rear plate you can remove, just count the teeth of the pinion, and the ring gear. If the pinion has 9 teeth and the ring gear has 37, it is a 4.11 ratio. You divide the number of teeth on the pinion into the number of teeth on the ring gear.
You can also do the same thing, if you have an open (non-posi) rear by jacking up one side and spinning the tire one revolution. Mark where the tire and the U joint are, spin the tire and count the number of revolutions of the U joint. If it turns 4 revs and a bit, it is around 4:11 or so. Not as accurate as you have to estimate the amount the U joint moves past your mark, but good enough for most people.
If you have a posi or locking rear, lift both rear tires.
