computer?
Old Mar 11, 2006 | 09:45 PM
gloosle's Avatar
gloosle
computer?
I have a 1988 ford f-250. I'm wondering if it has a computer in it, and if so, where can i find it? I am curious becuause i'd like to hook up my laptop to it, like some peopel i know do with their newer cars.
Thanks
gareth
Old Mar 11, 2006 | 09:52 PM
Argo's Avatar
Argo
Welcome to FTE. If you have a gasoline engine, you should have a computer under the dash, near the parking brake pedal assembly. As for hooking up your laptop to it,well, that'd be something I'd know little about...
Old Mar 11, 2006 | 10:05 PM
McLeod's Avatar
McLeod
Try this link:
https://www.ford-trucks.com/forums/s...d.php?t=470639
Old Mar 11, 2006 | 10:31 PM
Fully_Loaded's Avatar
Fully_Loaded
To hook your puter up you either need to go to fordfuelinjection.com and buy the sneev-IV box or be a computer guru. I have a sneec box that I would consider selling if you are interested PM me
Old Mar 11, 2006 | 11:18 PM
gloosle's Avatar
gloosle
thanks for the offer, but i don't want to spent that much money. it is possible to do it w/out one of these devices, am i correct?
Old Mar 11, 2006 | 11:27 PM
Blurry94's Avatar
Blurry94
If all you want to do is scan for fault codes, then you can buy a $20 scan tool from your local parts store. If you want to datalog real time engine info, then that's a different story. There's software out there that will allow you to do that, however, you'll need to check to see if the PCM in your rig has a DCL output so the PC/software can read, display and save engine data.
Old Mar 12, 2006 | 07:00 PM
Fully_Loaded
I think it might be difficult to read the puter off of an eec-IV since they have a very crude diagnostic port. Good luck though in your research.
