2Y vs. 2YABC
Old Mar 11, 2006 | 09:18 AM
bluzygent's Avatar
bluzygent
2Y vs. 2YABC
I am new to this site and I need to get an answer to a tech question about 460 cranks as I am in the process of building a 429CJ and planning to use 460 crank. What is the difference between the 2Y cranks? I know the years and such. But what if anything is the diff between the, 2Y, 2YA, 2YAB, 2YABC. Is the 2YABC better to use for high performance than a 2Y? I heard something about first level, second level, what ever that means? I heard that the 2YABC has more nickel or something? I have both cranks 2Y and 2YABC and just what to use the better of the two? I would appreciate any info you guys might have.
thanks/cheers - G
Old Mar 12, 2006 | 06:39 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 15, 2006 | 07:55 AM
bluzygent's Avatar
bluzygent
thanks for the welcome, tim.
still looking for an answer to my inquiry, if an answer is available. Any suggestion where else I might go for an answer?
bluygent
Old Mar 16, 2006 | 02:06 AM
deerhunter3814's Avatar
deerhunter3814
I know you are waiting to hear an answer, but all I can tell you is that I do not know of any differance in the ones you listed, or the one you did not list, 3y.
Maybe someone else has heard somthing.
Old Mar 16, 2006 | 03:10 PM
airharley's Avatar
airharley
Have you checked the ford interchange catalog? I know they sell the book at any book store. Might be worth a trip to take a look at it for more info. I did manage to find this at a ford site online though.
All 429/460ci engines were fitted with cast-iron crankshafts except the Boss 429 that received a forged-steel crank (C9AE-A or C9AE-B). All 429 cranks are marked 4U or 4UA. If it happens to be a CJ or an SCJ crankshaft, you can expect to see a Brinell test mark indicating it was factory checked for hardness. If you’ve found a 460 crank, expect to see a 2Y, 2YA, 2YAB, or 2YABC. After 1978, 460 cranks were marked with a “3Y.”
I hope this gives you a direction to go though.
Old Sep 10, 2025 | 07:00 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Thankyou
Old Sep 10, 2025 | 06:21 PM
cougrrcj's Avatar
cougrrcj
^ pre-87 vs later - that was due to external vs internal balance of the rotating assembly.
bjmayberry2
22
Feb 19, 2020 08:45 PM
jdhreiss
Dec 4, 2016 12:42 PM
ATC Crazy
21
Oct 25, 2015 08:08 AM
Boost-hard
20
Dec 17, 2012 02:33 PM
KJKozak2
Exhaust Systems
Jul 21, 2003 10:35 AM
