1978 - 1996 Big Bronco
Mass Airflow
Old Mar 11, 2006 | 07:25 AM
BigRedBronc's Avatar
BigRedBronc
Mass Airflow
Any of you know any companies that do aftermarket Mass Airflow sensors for the Bronco. I bought one back in 2003 from Pro-M, but they have since gone out of business. None of the other companies (Granatelli, Jet, etc...) make an aftermarket sensor for the Bronco. I have searched websites till my eyes hurt and cannot find a thing.
I originally replaced my factory MAF a few years ago (still have it) for two reasons;
1. Ford TSBs talk about lean driveability symptoms with a defective factory MAF, which I was experiencing.
2. The Factory MAF was not designed with optimum airflow in mind. They have a big bar splitting the MAF right down the middle and severely disrupting the airflow. The aftermarket MAFs have that bar removed and provide much better much smoother airflow.
I am looking now because when I went to discuss possible recalibration for new injectors with Pro-M, I discovered they had gone out of business. My factory injectors have 130,000 miles on them, and I have a brand new set of Accel injectors sitting on my workbench. The Accel injectors are 21lb as opposed to the factory 19lb, although Accel insists that the 21lb injectors are the optimum replacement for the factory injectors. My only concern is that the MAF Sensor is calibrated for 19lb injectors and I am going to have problems down the road.
I am considering going back to Ford and buying a brand new factory MAF, and crossing my fingers that the calibration curve will be OK. I am a little stymied as to why no one supports aftermarket MAF for the 96 trucks anymore, I suppose there just aren't enough of us out there.
I would appreciate any input, ideas, suggestions you might have.
Thanks,
Tom
Old Mar 13, 2006 | 11:58 AM
tite4x4's Avatar
tite4x4
i had almost the same setup on my 90 bronco from proflow/pro-m. it was a conversion kit that i put onto mine.
Apperently there are some aftermarket companies that still sell their products. i'm not sure if they still sell to the general public anymore. only to the other aftermaerket companies like Edelbrock. which is something you might want to check with. they have some of pro-m parts in the catalog i think. but it takes some research. i too am looking for updates in the matter
96F350dumpPA
Jun 16, 2014 12:35 PM
gman97005
Oct 25, 2013 03:38 AM
jrp79
Aug 29, 2013 01:52 AM
gman97005
Jun 23, 2013 08:01 PM
dumpsterdan
3.8 & 4.2L V6
Sep 20, 2004 02:28 PM
