What gears do I have??
Quick question guys. How do I know what gears I have in my truck? I am pretty sure it has to do with a letter in the VIN, is that correct? And if so, what letter stands for what gear?
Thanks!
Bill
Thanks!
Bill
I for the rear end, look at the tag on the pumpkin. a 3L73 is a 3.73 limited slip. 373 is a plain 3.73. The main gears for the F-250 and 350 were 3.73 and 4.10 gears. Some axle codes are on the sticker and if yours is there here are the axle codes.
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
F3 — 4.30 limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 chassis cab, narrow frame (dual rear wheels)
78 — 4.88 non-limited slip, F-450 chassis cab
G8 — 4.88 limited slip, F-450 chassis cab
75 — 5.38 non-limited slip, F-450 chassis cab
G5 — 5.38 limited slip, F-450 chassis cab
GW — 4.10 limited slip, F-450 chassis cab
98 — 4.88 non-limited slip, F-550 chassis cab
K8 — 4.88 limited slip, F-550 chassis cab
95 — 5.38 non-limited slip, F-550 chassis cab
K5 — 5.38 limited slip, F-550 chassis cab
KW — 4.10 limited slip, F-550 chassis cab
75 — Dana 80 (11,000 pounds GVWR), F53 recreational stripped chassis (motorhome)
95 — Dana 135 (13,500 pounds GVWR), F53 recreational stripped chassis (motorhome)
