rough idle-no ses light
Old Mar 9, 2006 | 11:25 PM
triton54's Avatar
triton54
My 97 Expedition has a rough idle, hesitates when i take off and sputters at times while moving at any speed. No SES light is on is there still a way to troubleshoot this w/o getting raped by the dealer or whoever. It has 131,000 miles i traded my acura for it now i finally have some american power...help me out guys.
Old Mar 9, 2006 | 11:26 PM
triton54's Avatar
triton54
Thanks, hope it works out.
Old Mar 10, 2006 | 02:18 PM
vwvan's Avatar
vwvan
I spent two weeks chasing a rough idle just like yours in my 99, 5.4L. Traced vacuum lines first,no leaks. Then tried to isolate a coil or plug problem. Not it. Next thought was o2 sensor, but no code so move on. Figures out rough idle was so bad that it couldn't be caused by one cylindar, so I moved to engine management. Did search here and found DPFS senors seemed to be a main topic. Paid $54 bucks for one at parts store and 10 minutes later motor running great. I then replaced EGR to try and pick up some fuel milage since I saved about $500 doing all the work myself.
Old Mar 10, 2006 | 09:21 PM
aagitch's Avatar
aagitch
What does the DPFS stand for?
Old Mar 11, 2006 | 01:13 PM
WillieWildcat's Avatar
WillieWildcat
You can find it under the layman's name: EGR Pressure Feedback Sensor
AIRTEX Part #5S2040
Look at your lines leading into the sensor also since they will most likely be full of junk.
Old Mar 11, 2006 | 09:43 PM
triton54's Avatar
triton54
awesome...egr looks like its the original one from when the truck was made.....i'll replace the 2 items and hope that does it.
Old May 12, 2006 | 01:53 AM
diamkirk2001's Avatar
diamkirk2001
How did that work out? I've got an 01 with 90k miles, and has a rough idle too. Was thinking of replacing same. Let me know what results if any you got.
I just had my injectors cleaned, throttle body decarbon, all that and still runs the same, a slight shake when idle. Thanks!
Old May 12, 2006 | 05:19 AM
triton54's Avatar
triton54
mine was real bad, it ended up being the #5 coil and plug.
Old May 12, 2006 | 03:33 PM
98expyinglendora's Avatar
98expyinglendora
have had the same problem with my 98, 5.4. it's gotten so bad that it started shutting off at real low speed or in idle. good thing, it finally spit out a code. P305 bad #5. Bought the COP last night (shop discount at Kragen, oh yeah!) and am replacing tomorrow. Hopefully that will do the trick.
Old May 12, 2006 | 05:51 PM
triton54's Avatar
triton54
good luck, felt like a new truck after i did mine
bigtexan99
Dec 10, 2017 06:50 AM
bly8397
Dec 11, 2012 07:19 PM
sealboy84
30
Jul 10, 2010 10:01 AM
Craig64
Jan 17, 2008 04:51 AM
