dual tank switch
Old Feb 9, 2001 | 05:03 AM
250two_by's Avatar
250two_by
dual tank switch
I never looked into any dealers yet but do they still make the valves for the dual tank switching for my 77 special? Was under the truck the other day and the valve assembly looks like it's on it's last leg with rust and all. Do they still make the assemblies so I can just plug it in and connect the lines or is this some type of retro that I have to do?
Old Feb 9, 2001 | 07:40 AM
martinb's Avatar
martinb
dual tank switch
I've had good luck getting parts from the chain stores for my '77 ( ie AZ or AA ) I'm amazed at what they have in stock for the 73-79's.
Old Feb 9, 2001 | 09:23 AM
buzzard's Avatar
buzzard
dual tank switch
Call a Ford Parts Dept. and ask them. I think most are linked by computer so if one dealership doesn't have it they can likely find another dealership with the part. Otherwise, check the junkyards. I have a '68 with the stock selector switch in perfect condition so not all old parts are worn out. You ought to have some luck with a little patience.
Old Feb 9, 2001 | 11:23 AM
DBF's Avatar
DBF
dual tank switch
I saw a switch in J.C.Whitney's catalog which might do what you want and be cheaper then Ford, and be useful for the older trucks with the valve and gauge on two different switches. It's set up to electricial switch the tank/gauge with the same toggle switch, so the toggle to the left of the wheel would would be the only item to switch, rather then reach along side the seat.
Jim
Old Feb 9, 2001 | 01:02 PM
fatforty's Avatar
fatforty
dual tank switch
Hi, give http://fordpartsonline a try they might have it they have alot of stuff in stock John
Old Feb 9, 2001 | 03:44 PM
390fe's Avatar
390fe
dual tank switch
Try your local parts store. They should be able to get them, if they don't have one on the shelf.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Feb 9, 2001 | 05:30 PM
jbhf250's Avatar
jbhf250
dual tank switch
My manual tank switch went south a long time ago(1972 f250). I installed an electrical type and found that the `factory` dash switch had extra wiring there to allow you to switch the solenoid type valve. And the gauge reflects which tank you are on
Might try that if the hand valve is hard to find.
__JOHN__Õ¿ö
FTE Club #7
Member-
http://www.cruisin-north.com/
Santa Rosa, Calif.
72 F-250
ICQ#6030753
http://www.ford-trucks.net/users/jbhf250/
https://www.ford-trucks.com/pictorial/big/1972_f250_2.html
Old Feb 9, 2001 | 07:18 PM
250two_by's Avatar
250two_by
dual tank switch
Thanks for all the info. First I'll try the parts stores and go from there.
Old Feb 9, 2001 | 07:27 PM
jowilker's Avatar
jowilker
dual tank switch
capn_zed
Oct 2, 2013 08:01 AM
jayro88
Sep 24, 2013 01:15 PM
fast68
Nov 23, 2007 04:03 PM
Imdok
Oct 13, 2007 10:01 PM
tawd77
Feb 8, 2007 04:56 PM
