upper rad hose
Old Mar 9, 2006 | 01:08 PM
bigred00's Avatar
bigred00
upper rad hose
Does somebody make a upper radiator hose that you do not have to remove to change serpentine belt? Thanks for your help!
Old Mar 9, 2006 | 01:15 PM
PSNut's Avatar
PSNut
Yes.It's available from most good auto parts stores like NAPA and is used in the dual alternator configuration. I just put one on myself but had a tough time locating one wihtout going to the Stealerships. About $20 if memory serves me correct.
Nut
Old Mar 9, 2006 | 02:25 PM
wilbur996's Avatar
wilbur996
Yes, as PSnut said. But make sure you tie the rad hose to the alternator or is can come in contact with the serpentine belt. The alternator has a nice little half round spot for the rad hose.
Old Mar 9, 2006 | 02:46 PM
hink10's Avatar
hink10
Try this http://www.rockauto.com/ I got mine there, price is $7.55. There is a 5% off coupon code, 388075339147 until May 9th.
ColtM4's Avatar
ColtM4
Go to NAPA and tell them you want the upper hose for dual alternator. Or do a search and you should find the part number.
Old Mar 9, 2006 | 03:09 PM
ColtM4's Avatar
ColtM4
Napa 9066 is the hose number.
Old Mar 9, 2006 | 04:25 PM
clintbonnie's Avatar
clintbonnie
Wonder why Ford used the hose that goes around the belt in 1999 and changed to the "thru" the belt hose in 2000 .. weird..
Old Mar 9, 2006 | 04:30 PM
PSNut's Avatar
PSNut
Ford bean counters at work.
Nut
