292 Modifications
Old Mar 8, 2006 | 10:54 PM
Fordication's Avatar
Fordication
292 Modifications
Ok, I have the motor home and it has been rebuilt. Now I need to add the acc. items and do the modifications I have heard about here. Do I need to drill the holes in the valley that you guys were talking about. What other things should I do to add life to the motor. Any modification ideas would be appreciated. Ed
Old Mar 9, 2006 | 07:08 AM
312's Avatar
312
i wouldnt drill the holes in the valley.that was something racers did away back and is no longer nesasary if it ever was.
Old Mar 9, 2006 | 10:53 AM
46yblock's Avatar
46yblock
I agree with 312 on the holes, based upon what I've read. At best they are not necessary, and at worst they could weaken the block. Make sure you degree in the cam if it hasnt already been done. It would be best to get someone experienced to help, but if that isnt possible, you can get through it with an article or book on the subject. Also, measure and record the distance between the top of the piston and the deck, and cc the heads. The measurements wont make the motor any better, but you can calculate the static compression. Tools for cc measurements are available at mail order parts houses.
Old Mar 9, 2006 | 08:13 PM
Fordication
thanks guys. I was not looking forward to drilling anyway. I found the article from hot rod I was looking for. All of that seems like a bit much. I think I will just finish puting it back together and get it painted and ready. Ed
strokermax
15
Nov 3, 2014 02:02 PM
crawlfish
Jun 13, 2005 12:52 PM
Dixie95
Mar 24, 2004 09:33 PM
damonlan
Exhaust Systems
Jul 10, 2003 07:25 PM
tallica2002
Nov 6, 2002 08:07 PM
