best spot for probe
Old Mar 8, 2006 | 10:10 PM
250turbo's Avatar
250turbo
best spot for probe
moving pyro probe before turbo,whats best spot?
Old Mar 8, 2006 | 10:48 PM
ltfox's Avatar
ltfox
I put mine in the manifold right before the up-pipe. Its real easy to get to under the truck and is where most put it I think.
Old Mar 9, 2006 | 08:08 AM
plowhand's Avatar
plowhand
Playing in the Dirt
I installed mine in the Y pipe before the turbo. That way it reads both sides. Easy install, just use progressively larger bits, go slow, & have the ruck running to blow any small particales out. Several guys around here have installed thiers in this location but both locations work fine.
Old Mar 9, 2006 | 08:19 AM
barebackjake's Avatar
barebackjake
in the collector pipe also. it still only gets one side, but i like to be as close to the turbo as possible, there a divider in the collector pipe.
Old Mar 9, 2006 | 10:37 AM
1969fordguy's Avatar
1969fordguy
On the driver's side toward the rear as far back as possible. I used only one drill bit and watched all of the shavings fall away from the hole. When tapping it I used grease to capture the fine shavings. As an added precaution I used a shop vac on the hole to suck out anything that got in.
Old Mar 9, 2006 | 07:06 PM
djf48's Avatar
djf48
https://www.ford-trucks.com/forums/s...d.php?t=386419
check this link out, it helped me
Old Mar 11, 2006 | 04:34 PM
250turbo's Avatar
250turbo
thank you all for tips, going with driver side back
charlie555
Jun 16, 2016 10:01 PM
big ole ford
16
Mar 7, 2014 09:01 PM
sparkkky
Apr 20, 2011 09:37 PM
Full Throttle
Mar 19, 2009 11:50 AM
Milwaukee,WI
Jan 12, 2006 10:45 PM
