brake question
Old Mar 8, 2006 | 07:21 PM
harpo17's Avatar
harpo17
brake question
I'm installing power brakes on my 71' from a 79', do I have to use the same prop valve off of the 79', or could I just skip it altogether? Also the spindles, will they adapt to my I-beams or not? The old ones are just a pain to remove, so I was going to torch them off just after the pins! Adding them to my beams w/new pins.
Old Mar 8, 2006 | 07:45 PM
thesprocket26's Avatar
thesprocket26
If you are doing the disc conversion you will need the proportioning valve. Are you talking f100/150 spindles? You might not now but, there were a few different trucks made in 1971 and 1979.
Old Mar 8, 2006 | 07:55 PM
harpo17's Avatar
harpo17
The donor is a 1979 f-150, the other is a 1971 sport custom.
Old Mar 8, 2006 | 08:02 PM
thesprocket26
Yes, anything from 73-79 f100 or f150 will fit. If you buy new kingpins, buy for the year of spinde you will be using.
72CC428
23
Nov 26, 2017 08:49 AM
big ole ford
Jul 18, 2016 09:17 PM
f100today
Apr 2, 2016 08:09 PM
elyons1970
Apr 25, 2011 01:41 AM
biggut
18
Dec 23, 2008 12:06 PM
