Modular V10 (6.8l)
stans y pipe
Old Mar 8, 2006 | 07:11 PM
fordboy2's Avatar
fordboy2
stans y pipe
Can somebody give me a contact to get one of these, I am purchaseing a set of gibson headrs and want to do this mod at the same time, I also hope to put a flow master fm70 on at the same time, anyone have a similar setup is it real loud compared to stock? Thanks in advance
Old Mar 8, 2006 | 08:50 PM
Antelope V-10's Avatar
Antelope V-10
Google Stan's headers in Washington.
Old Mar 9, 2006 | 11:24 AM
captchas's Avatar
captchas
Guest
don't use stans! it causes a flutter in the exhaust. get the one from summit like monsta used. it's made by flow master and is much more like a true header 2 into one , where stans y dumps on top of the other and causes the flutter.
Old Mar 9, 2006 | 02:34 PM
captchas's Avatar
captchas
Guest
not stans
did some digging for you the part number you want is from summit racing. it's a flow master FLO-Y250300 cost is $39.88 type in the number it shows the photo
you can use a fm 50 big block or a 70 all depends on how you want the sound,i have a 70 on now ,tryed a 40 to loud inside the 50 better ,great out side for my old fart ears the 70 is perfect
Old Mar 9, 2006 | 06:10 PM
Antelope V-10
I have to disagree that Stan's Y causes flutter. Yes I know have a slight flutter after installing the y, but I think it is ultimately caused by the lame factory exhaust manifolds. The gentleman above wants to do the Stan's plus Gibson headers. I say go for it. It would definately answer whether the stock exhaust manifolds were the root cause or not.
Old Mar 9, 2006 | 08:00 PM
captchas's Avatar
captchas
Guest
maybe maybe not.we need more info as to what one dose and dosen't , the flow master has a longer collector . the gibson headers from ebay o-yah, 200 ver my 500 set from ford,
Old Mar 9, 2006 | 08:23 PM
Antelope V-10
I found this old thread where after skipperw got his y-pipe made with the Flowmaster, he has flutter too.
https://www.ford-trucks.com/forums/s...d.php?t=380707
Old Mar 10, 2006 | 08:25 AM
captchas's Avatar
captchas
Guest
yes i know both you and skip had it after a stans pipe job. but yet monsta seems not not to ? 2 guys get it! 1 dosn't . 2 of 3 get flutter. i'd be more inclined to go flow master doing the same job .
same with the headers the gibson work as well as my high priced ford racing ones . i'd rather have the 300 in my wallet for some other toy or gas for a while.
Old Mar 10, 2006 | 09:07 PM
mdpopo59's Avatar
mdpopo59
I have the Gibson style Tiawan headers and a FM 70. Stock rams horn Y pipe with no restriction. It seems fairly quiet to me. You can hear it more at idle that driving down the road. Although the other day I was driving though a tunnel in DC and floored it, it startled me and was louder than i thought. But it's still that same V10 sound.
Old Mar 10, 2006 | 09:35 PM
captchas's Avatar
captchas
Guest
isn't that sound great? all by it self and it can turn heads . only bad problem i have is all the wild hemi lovers see my truck and run the other way now.
Old Mar 10, 2006 | 10:57 PM
Monsta's Avatar
Monsta
Sit. Stay.
I get flutter at certain RPMs and throttle settings. I couldn't hear it at first. Now when I try I can hear it.
Old Mar 11, 2006 | 08:52 AM
Antelope V-10
Well now that Monsta has flutter too, I hope fordboy2 proceeds with his setup. That should be the answer to whether or not it is the exhaust manifold design or not.
Old Mar 11, 2006 | 09:01 AM
captchas's Avatar
captchas
Guest
time to sit back and wait to see the big IF and DOSE or NOT. best thing is down here in the v10 area is every one of our personal mistakes can or dose help the next guy to avoid that problem and build a better truck. plus save cash in the long run
ok monsta says a little . thats still better then dose have. lets wait this one out before makeing any more errors in judgement.
Old Mar 11, 2006 | 02:03 PM
Monsta's Avatar
Monsta
Sit. Stay.
I should note that I only really hear it if the windows are down and I'm passing a immovable object like a wall or something. I couldn't even tell you the RPM/throttle position that does it.
I do not think it hurts anything but is only and annoying characteristic of the V10.
