dark blue
Old Mar 8, 2006 | 01:57 PM
4.9inline6's Avatar
4.9inline6
dark blue
soon, i will be starting to work on the body of my truck. for paint, i am leaning towards the ford dark blue. has anyone ever thrown a little metalic flake in the paint?
another thought i had was painting it the dark blue but putting black metallic flake in the clear.
any thoughts on this?
chris
Old Mar 8, 2006 | 04:29 PM
plowhand's Avatar
plowhand
Playing in the Dirt
If you hand mix the metalic into a paint, and later you need to repaint a section (due to accident ect.) it is hard to match the paint again. I would suggest using a premixed paint. I have used Dupont to paint ford's and have found a color matches with the metalic in it. Now all I have to do is write down the paint code, and I can match it perfectly in the future. I just did my '95 250, Dark Green OEM paint, used Dupont with metalic. Same color only with metalic, looks great. Good luck on whatever you choose.
Old Mar 9, 2006 | 08:26 AM
4.9inline6's Avatar
4.9inline6
i talked to my teacher and i think i am going with some already mixed, for the reasons you just stated.
Old Mar 9, 2006 | 11:58 AM
plowhand's Avatar
plowhand
Playing in the Dirt
I think you will be happy with your choice. Post us some pics when you get it painted.
Old Mar 9, 2006 | 03:12 PM
4.9inline6's Avatar
4.9inline6
i will...itll be awhile because i have quite a bit of body work.
chris
Old Mar 10, 2006 | 08:18 PM
Rocket Racing's Avatar
Rocket Racing
Flake looks great, but as mentioned, makes repairs harder. If you weigh out the flake on a gram scale, and blend any repairs, you should be able to make it work. Instead of flake on my current project, I used started with a stock color and made some adjustments. I used Coarse Starflake Metalic instead of Medium Starflake, and I added lots of Violet Pearl to the base blue color. It really came out nice. It also looks cool when I used it to tint the bedliner.
Not sure if my signature is showing up, but some pic's are located here if it does not show up.
lifted77f250
Aug 6, 2008 08:59 PM
firebug
Feb 6, 2008 08:01 AM
1970Custom
Paint & Bodywork
May 11, 2007 01:01 PM
earnhardtracer38
Paint & Bodywork
Feb 28, 2006 06:25 AM
aerocolorado
Paint & Bodywork
Jul 15, 2004 11:31 AM
