Top Speed
Old Jan 14, 2001 | 09:04 PM
  #31
proud66owner's Avatar
proud66owner
Top Speed
my friend had a beefed up 71 pushin about 275-300 ponies and he said it would only run 100 but that's what is speedometer said but the truck was still going after it was pegged.
proud66owner
justin
i would rather push a ford than drive a chevy
Old Jan 29, 2001 | 07:52 PM
  #32
FE427TP's Avatar
FE427TP
Top Speed
Old Feb 17, 2001 | 08:27 AM
  #33
fordman460's Avatar
fordman460
Top Speed
my 76 4x4 with a 360 and a 4 speed would do over 100 as i recall it had 4.10 in back and 4.09 in the front. my 79 bronco with the 351m and a cam was clocked at 145on the highway and my 74 f250 camper special with a 460 will peg the speedo at over 100 and stock except for a carter 750cfm carb. its also got about 300,000 miles.
Old Feb 17, 2001 | 09:25 AM
  #34
Nitro's Avatar
Nitro
Top Speed
A bronco doing 145????? I dont mean to call you a liar, but that is almost defying the laws of physics. Not one of the old Fords I have seen has been able to push it to 145, yes I have seen 130 but nothin that fast. I mean there are some NEW Camaros out there that dont go that fast, and an old ford is designed slightly more "heavy duty" than that.
Nitro
Old Feb 17, 2001 | 10:21 AM
  #35
fordman460's Avatar
fordman460
Top Speed
nitro, i appreciate your input. but that was a rounded version of actual radar and mathematical figuring. i dont remember the formula any more but it was something to the effect of tire height*rpm/??????=speed
ive found it to be accurate every other time ive used it so i would have to believe it. and like i said the motor wasnt stock either all i know for sure as i bought it built was it had a cam dual exhaust and a 4v. the actual speed was 143.?? by the math and 144 on the radar.
Old Feb 17, 2001 | 04:47 PM
  #36
Ratsmoker's Avatar
Ratsmoker
Top Speed
I have a 1970 f-100 with a stock 2bbl 390 and 3.25 gears and I know it will do 85 with a lot of pedal left. If I had to guess I would say top speed would be from 95-100, but I'm afraid to try. Everybody needs to understand though that speedometers were never calibrated for 100 mph so its always best to use a tach and do the math. Oh and when i get done building my motor it should have about 400hp and no matter what gears I use I don't think 145mph in an old pickup is possible. Gonna have to call bull@#$% on that one.
Old Feb 17, 2001 | 05:18 PM
  #37
PetesPonies's Avatar
PetesPonies
Top Speed
My stock 69 360/3 speed ran like a scolded dog. I have had it to 100 several times. Now the same truck has a 428 4 speed; top speed?????????????????? )
Old Feb 17, 2001 | 05:27 PM
  #38
loudfords's Avatar
loudfords
Top Speed
My 79 topped off about 90-95 mph with a stock 351M and it had to work to get there. With the 351W one morning I pulled onto the freeway about 1/2-3/4 throttle it almost hit the 0 and was still pulling strong and had lots of rpm left before I decided it was a little silly to be driving that fast on the way to work. The truck felt rock solid too at that speed; no wandering or shakes whatsoever.
1979 F150 Custom: 75 351W, Edelbrock & Holley
1987 F150 XLT Lariat: 88 351W EFI
Chevy 454: waiting for a truck (Mazda?Nissan?)
Old Jun 13, 2021 | 09:36 AM
  #39
joezam2009's Avatar
joezam2009
John,
Would you be willing to chat about a 1969 Ford F250 with a C6 and ford 9" in it? I just purchased it and had a few question, you seem very knowledgeable. Here's my email and I can give you my number thru that.
Thanks
my email is joezam2009@gmail.com
Old Apr 7, 2022 | 08:24 PM
  #40
pantera913's Avatar
pantera913
my 1970 f250 with 390 and new process 435 3.73 rear gears tops out at 50mph in 4th gear with 4500rpms
Old Apr 7, 2022 | 08:34 PM
  #41
arnegrant's Avatar
arnegrant
I had a straight six with a four speed that sounded like it was coming off its rails at 65 mph.
I've had a few that would go in the 90s.
I think it's gearing, and then the motor.....
Old Apr 7, 2022 | 08:56 PM
  #42
85e150's Avatar
85e150
Only if you have 13" diameter tires--like off a lawn mower. Or you have a 4x4 and are in low range.
Old Apr 7, 2022 | 09:03 PM
  #43
tbear853's Avatar
tbear853
Was a '49 Ford, F-head V-8, three speed, overdrive too. Run 80+ in 3rd gear, but would top 100 in 2nd/OD.
Oooops, was a car, one of my uncles cars, was in the 1960s, scary ride that was too, was on back roads of Franklin County, Mom liked to have killed him over that deal when she found out. Ever see water poured out in a Mason jar cap burn with a blue flame?
Of my '77 truck, I don't think I ever, well maybe once exceeded about 75, just saw no percentage in it. The time it maybe did was in Georgia passing a tanker near Chatsworth. It's maybe seen 70 once or twice as merging onto 81, but 63 is the sweet spot.
Old Apr 8, 2022 | 08:01 AM
  #44
FuzzFace2's Avatar
FuzzFace2
Howany of you check if the speedo is on the money?
Change tire size and now the speedo is off same with axle gearing.
Dave ----
Lookuphere1
Apr 28, 2018 07:24 PM
redbeard_trucks
20
Jul 2, 2011 05:44 AM
'74390
13
May 24, 2010 08:17 PM
FoMoColover
Feb 4, 2007 08:19 PM
