have this weird feeling while cruising at a constant speed.rite around 30mph.at first i thought what i was feeling was a bent wheel as thats what it feels like but when i let off the gas its not there, only while the gas is applied do ifeel it.its a small pulsating feeling.
i was wondering if it could be time for a tune up.i have had two other problems that were simular but not quite the same. one was the fuel pump and the other the dpfe valve both which have been replaced.i also just put in a new fuel filter.
truck has 184 k on it, its a 5.8.plugs and wires are about 2 years old.
tune up time for sure. get some autolite,motorcraft copper plugs. some ford 9mm wires and new cap/rotor . then set your timing at 10*btdc. what year is this?
it doesnt do it all the time. i also just found i hade two cracked brack shoes in the back. this might of been the problem too. i will see if it does it now.
had the same prob with wifes e 150 with the 302 and after tearing into it to do the tune up (wasnt anything to do with the plugs wires cap and roter)it was the o2 sensor going out replaced it and it drove great no pulsing a real relief still got the tune up but problem was still there might want to check the condition of the sensor while your your doing the tune up
