1988 351W codes
Old Mar 7, 2006 | 09:58 PM
RKG's Avatar
RKG
1988 351W codes
I did both the koeo test and the koer tests today on my 1988 f150 w/ 351W and c6 transmission. I got three codes on the koer test.
Code 13 - idle low
Code 33 - egr fault - not closing properly
Code 44 - thermactor air system fault
I got no codes on the koeo test this morning.
I'm open to suggestions as to what to do.
Thanks for any help you can give me.
Ron
Old Mar 7, 2006 | 10:52 PM
77bigblock's Avatar
77bigblock
Was it warmed up when you checked it this morning?
Old Mar 8, 2006 | 09:09 AM
RKG's Avatar
RKG
Yes it was warmed up. I made sure of that.
Old Mar 8, 2006 | 11:51 AM
pfogle's Avatar
pfogle
The first one can be caused by a clogged air filter, bad TPS, bad PIP, or bad ICM. The second one is pretty common, the last one is one of the square solenoids on the passenger side valve cover.
Old Mar 8, 2006 | 11:53 AM
RKG's Avatar
RKG
I rechecked the codes this morining with the rig well warmed up.
Got and 11- no codes w/key on engine off
got 13, 33, and 41 again w/ engine running.
thanks,
Ron
SJP
Mar 18, 2016 08:24 PM
jdthedj10
Jan 11, 2016 04:15 PM
deshet1980
16
Dec 28, 2015 03:32 AM
RIKIL
Mar 9, 2013 01:43 PM
