help, turbo problems
Old Mar 7, 2006 | 09:12 PM
gotbeatbyadiesel's Avatar
gotbeatbyadiesel
I have a 04 psd with edge platnuim and 4.5 '' exhaust with no cat or muffler. recently when i turn the truck off i can hear the turbo still spining. I think that means there is a problem. if i take it into the factory will that void the warranty due to the exhaust. i know they will with the edge programer. i can take that off easy. please let me know if the noise made is a problem. i have never heard it before on any other diesel i have had
Old Mar 7, 2006 | 09:41 PM
JD717's Avatar
JD717
I think thats just the turbo spooling down. more than likely its quite fine, and normal. the reason you noticed it, is probably because you've got that larger exhaust that lets the exhaust breathe better, and the turbo spools better, and doesnt slow down as much because theres less backpressure to slow it.
Old Mar 7, 2006 | 10:20 PM
kw5413's Avatar
kw5413
Welocme to FTE. When you get a chance you will find great info in our tech forum.
https://www.ford-trucks.com/forums/s...d.php?t=303583
Old Mar 10, 2006 | 06:54 AM
pamelbert's Avatar
pamelbert
I would only worry if you didn't hear it still spinning
Old Mar 10, 2006 | 08:21 AM
fordboy_52's Avatar
fordboy_52
you can hear the same things on trators and farm machinery, ours can spin for upwards of a couple min. just make sure u let it properly cool down and u will be fine
Matt
Old Mar 12, 2006 | 07:24 PM
handyman43358's Avatar
handyman43358
Any diesel I've ever heard with a performance exhaust on it, or even a straight exhaust, the turbo will still spin even after shut off. It's a good sound if you ask me!
Old Mar 12, 2006 | 09:06 PM
CanadaGuy's Avatar
CanadaGuy
Are you sure it's the turbo you hear? The cooling fan makes noise for a few seconds after shutting down.
