94 Explorer engine jingle
Old Sep 4, 2006 | 04:07 PM
MrSki's Avatar
MrSki
Originally Posted by Jharger
Also of course, a dirty MAF sensor causes a bad ping. If you didn't, you should remove it and shoot it with carb cleaner - use Berryman's as it leaves no residue.
Seems like this very informative intelectual left you a short cut clue here...but by this time you've likely already cleaned it at least once...sometimes cleaning does not work so try swapping with your other MAF.
There could be other issues that don't throw codes...like a bad fuel pressure regulator. PCm tells it give me so much injector duration but at a lesser pressure, less fuel is delivered. If all your electrical controls check out OK, look at the fuel side. Clogged injectors will runn it lean too.
180K on my engine so far and the fuel system has been great...knock on wood.
Old Oct 18, 2006 | 10:33 AM
laracroft's Avatar
laracroft
Well It's fixed!!!!!
It was the MAF sensor, tryed three different maf sensors, all checked out good, but only the third one fixed the problem.
So no more jingle!
Old Oct 18, 2006 | 12:01 PM
MrSki's Avatar
MrSki
So no more jingle!
Sweet!
Were these all brand new units? I've got a larger Granatelli unit on mine that tends to run it a little lean and in the summer heat I have to run at least 89 octane. What octane have you tried through this?
Old Oct 18, 2006 | 03:06 PM
laracroft's Avatar
laracroft
They were all used that checked ok, but only one fixed the problem. reg grade 87 octane. It was a MAF off a 91 Explorer that fixed it.
Old Oct 18, 2006 | 08:49 PM
MrSki's Avatar
MrSki
Next time you suspect pinging, try high octane and see if it goes away. That will at least narrow it down to pinging and then there are more defined possibile root cause problems.
I had a 1990 VW Jetta that pinged in the summer. 100+ octane and it went away. So I had 2 distributor timing settings. One for summer, one for winter.
bigb56
Sep 8, 2014 09:04 AM
Rongor
2009 - 2014 F150
Jul 20, 2014 07:49 PM
zloetakoe
19
Jun 19, 2013 11:23 AM
MARZ06
Modular V10 (6.8l)
Aug 30, 2005 12:43 PM
Salmonhead
1978 - 1996 Big Bronco
Apr 22, 2004 10:25 AM
