Clutch noise
Old Feb 18, 2001 | 09:00 PM
tra's Avatar
tra
Clutch noise
I have ever thing new clutch pressure plate throw out bearing
and and autozone adjustment lever that goes on the equalizer i think. But when u push the clutch in you here a noise every time sorta like a clicking what could this be. Major or minor Thanks
Old Feb 19, 2001 | 11:28 AM
mattyk6's Avatar
mattyk6
Clutch noise
Old Feb 19, 2001 | 01:04 PM
Art's Avatar
Art
Clutch noise
[font size="3" color="#191979"]
Could be major, could be minor. Please specify the year, model, and engine. Does it make the noise when the clutch pedal is down 1.5", half way down, just at the bottom, or all of the time? Is the noise a solid sound, a hollow sound, or a tinny (cover plate) sound?
It could be a bad throwout bearing, a bad pressure plate (warped/bent finger), or the fork contacting the pressure plate. Just stabs in the dark. The more descriptive the question, the easier it is to answer.:-)
Art
Old Feb 19, 2001 | 07:51 PM
tra's Avatar
tra
Clutch noise
About half way down clunk noise
Old Feb 20, 2001 | 01:07 PM
Art's Avatar
Art
Clutch noise
Does it clunk just once, or is it a repetitive noise that continues on until you release the clutch pedal?
If the noise is just once, I suspect worn pedal bushings or a mechanism problem (worn bushings, worn linkage connections in linkage, etc). Go under the truck (with the engine off, of course) and have someone push in the clutch to determine where the noise is coming from.
If the noise continues until the clutch pedal is relesed, I need more info to determine which clutch you have in the truck.
Art
Bob Shumway
15
Dec 3, 2014 04:08 PM
jFa350
Jun 8, 2013 01:46 PM
Jmatthews
Apr 15, 2010 06:32 PM
divedigger
Nov 25, 2006 12:51 AM
bob59
Oct 25, 2006 07:31 PM
