Computer Chips & Tuners
Superchip & 97 shift points?
Old Mar 7, 2006 | 08:21 PM
Fordxcab4x4's Avatar
Fordxcab4x4
Sorry if you have answered this question already I have searched until my eyes hurt, LOL Can the shift points be modified on a 97 with my Superchip getting a reflash?? I have dropped 4:10 gears on my truck and would like the shift points touched up a bit???
Old Mar 7, 2006 | 09:53 PM
pronstar's Avatar
pronstar
You have the same situation I do. It's no biggie, but it might take one or two shots at it to get them just where you want them.
Tell whoever programmed your chip that you need your shift points raised higher. Every time I get a re-tune I have the same issue. Make sure you tell them about your gears, and note at what RPM you get the 1-2, 2-3 & 3-4 upshifts.
Did you change your VSS gear so that your spedo reads somewhat accurately? I'm about 7% off, but there's nothing I can do about it as I've got the smallest (I think, might be the largest) VSS gear available. It's one of those extremes - biggest or smallest, can't recall...
Old Mar 8, 2006 | 07:36 PM
Fordxcab4x4
Thanks for the info, O have not changed the VSS yet I have not had the truck home long enough since the gear change, what gear did you go with and tire size? What tooth VSS did you go to?
Old Mar 8, 2006 | 08:55 PM
pronstar's Avatar
pronstar
I've got 4.10s.
Now that I think about it, I went with the smallest VSS gear that is available for this year of truck. I believe Steeda had a one-tooth-smaller gear from a Mustang that was supposed to work, but a few guys online who tried it said it wore-out after only a few thousand miles.
I've got street tires, 285-60R18 on 18-inch 2000 Lightning wheels. The outside diameter is about 32 inches, I think (could be wrong about this). Performance increase was fantastic.
Old Mar 9, 2006 | 07:59 AM
Fordxcab4x4
Where do you buy the VSS gears Ford dealer?
Old Mar 9, 2006 | 11:14 AM
pronstar's Avatar
pronstar
I can't recall where I got mine online...I remember they had a nice calculator to help out.
I did find this site:
http://www.transmissioncenter.net/sp...n_______va.htm
Looks like they have an online calculator as well. I'd call them prior to ordering, to make sure you get the correct one.
Old Mar 10, 2006 | 09:33 AM
MotorHaven Guy's Avatar
MotorHaven Guy
Yes, they can be modified by the Microtuner.
Old Mar 10, 2006 | 01:50 PM
pronstar's Avatar
pronstar
Not on a 1997...or have I been led astray all this time?
We've got a mechanical odometer, not a digital one.
Old Mar 10, 2006 | 02:01 PM
Fordxcab4x4
I emailed Superchips and this is what they told me
We can not recalibrate for change in tire height or gear change with our tuning.
Old Mar 10, 2006 | 02:13 PM
MotorHaven Guy
My fault... I wasn't paying attention to the year. 99 and newer only with anything related to that.
Old Mar 12, 2006 | 04:57 PM
Fordxcab4x4
Something doesn't seem right, the computer tells the 4R70W on the 97 model year truck when to shift correct?? So then why can't the tuners change the chips to allow shift point changes?
Old Mar 12, 2006 | 08:02 PM
pronstar's Avatar
pronstar
They can. At least, they can with a 4-bank SCT custom tune chip. Not sure about the other Superchips stuff.
I THINK it has to do with the 4.10 gears were running. I don't think the factory ECU has a map for this short rear-end, so it's a bit of a PITA to get the shifting down right...but I'm not smart enough to tune my own truck, so I could be mistaken.
Guys with 3.73s and taller (lower numerically) don't seem to ever have this problem. But I've spoken to a few guys online with 4.10s and it seems we're all in the same boat.
At least, that's what I think is going on. I've had several dyno tunes, and I always have to go back at least once to get my shift points where I want them.
