ignition bypass
Old Feb 20, 2001 | 03:26 PM
f10074's Avatar
f10074
ignition bypass
Old Feb 20, 2001 | 06:35 PM
thebeast's Avatar
thebeast
ignition bypass
I have a 79' f-150 with a 4x4 and I would like to disable the start only in park and neutral so I can start it in gear. My 70' f-100 sports custom has this device disabled so it will start in gear. Can any please tell me how to do this so I can start my truck in gear.
thanks
Old Feb 20, 2001 | 06:38 PM
otto's Avatar
otto
ignition bypass
why on earth would you want to start in gear, they put that on there for a reason not only do you endanger yourself but also the people around you , does anyone here agree with me on this ???????
Old Feb 20, 2001 | 06:52 PM
thebeast's Avatar
thebeast
ignition bypass
On my 70' f-100 I have a intake leak and it will die when idleing at stop lights. It is a lot easier to start it in gear than tring to put it in park or neutral. Also I do a lot of mudding and if it dies when I am in the middle of a giant mud hole it is easier to start in gear and continue mudding so I don't get stuck. If I quit rolling I will probably get stuck in my serious mud holes. Thats just my reason behind the disablement.
Old Feb 20, 2001 | 07:36 PM
MSTRAWN's Avatar
MSTRAWN
ignition bypass
Only bypass that thing in an emergency, and just to get to a parts store. All it takes is a moment of distraction, mind on something else, to get some one seriously hurt.
1977 F-100
300 I-6 / C-4
Offy intake w/holley390
Hedman headers w/duals
MSD6
Whiter whites/Brighter brights
Old Feb 20, 2001 | 09:22 PM
jowilker's Avatar
jowilker
ignition bypass
Guys I disagree. Both of my 66s will crank in gear. I know that, and it isn't a problem. My red truck with the manual choke is the more likely to shut down while warming up, and I just twist the key and mash the gas when it hits. Once the trucks are warm, they don't cut off anyway.
My 2 cents worth. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01]
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners]
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Feb 20, 2001 | 10:09 PM
stingray's Avatar
stingray
ignition bypass
My starter neutral switch has been disconnected as long as I've had the truck. I got tired of jiggling the stupid lever, and it was easier to bypass than to adjust. Just trace the wiring from the switch itself until you come to the 4-pin connector usually located near the transmission dipstick handle. Just cut the two red and blue wires and short them together.
Old Feb 21, 2001 | 08:36 AM
glenn 79's Avatar
glenn 79
ignition bypass
I agree 100%.
Glenn
