I've been breaking down my brothers truck to experiment and just learn more about engines and i just pulled off the throttle body(btw its an 85 f150 302 fi) and intake manifold and i went to autozone and the guy recommended using chemtool b-12 cleaner on the throttle body and that worked like a charm and all the deposits just sprayed right off. He recommended soaking the manifold in mineral spirits, a kind of paint thinner. I tried this and it ended up costing 40 bucks or so which i find reasonable but the results were not. The mineral spirits removed a little of it but nothing compared to the b-12. I was wondering what you all think is the best way to remove all the deposits especially getting down into the manifold where i cant reach.
Seafoam work great.http://www.seafoamsales.com/deepCreepConsumer.htm , the only problem with cleaning high carbon deposit areas, is the carbon is going go down the exhaust pipes and settle in the oxygen sensor and the catylitic converter. When you use this stuff, after take the truck for a long ride and try to keep it at the higher rpm's with out getting a traffic viotation ticket (use the lower gears on trans), this will help to remove the carbon build up from the exhaust system.
Some things that worked for me, but while the engine was running...
Rubbing Alcohol will work, and will also absorb water in the fuel so it will burn. Marvel mystery oil in the gas and oil works good too. If you have a sticky valve, put some marvel mystery in her and it will clean her up good.
After any cleaning job like that with the engine running, there is a chance of fouling the o2 sensor and plugging the catalitic converter.
