What does the A/R ratio mean?
Old Mar 7, 2006 | 03:22 PM
cangim's Avatar
cangim
Never given it much though until I started rebuild process of transmission and Turbo. Current turbo is a 1.1 AR. Does that relate to the exhaust pressure to boost pressure? ex. if the AR rating was 1 it would take 1lb exhaust pressure to make 1 lb of boost, equally 20 lbs exhaust, 20 lbs boost. Am I right in this or is the AR rating relating to something else?
Old Mar 7, 2006 | 03:52 PM
Kwikkordead's Avatar
Kwikkordead
Curious minds want to know here as well. That would be me and the voices in my head.
Old Mar 7, 2006 | 04:05 PM
blhfla's Avatar
blhfla
The turbine housing A/R (area/radius) ratio is the area (A) of any turbine inlet scroll cross-section divided by the distance from the center of that cross-section to the center of the turbine shaft (R). For any given turbine housing, A and R vary in the same proportions, so all As divided by their corresponding Rs yield the same dividend--which is the A/R ratio.
Check here for more info:
http://www.hotrod.com/techarticles/e...bo/index1.html
Old Mar 7, 2006 | 05:47 PM
cangim's Avatar
cangim
That is great information, thanks for the link.
Old Mar 7, 2006 | 06:08 PM
Kwikkordead
Yeah, good link, thank you.
Old Mar 7, 2006 | 06:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
this should also be helpful.
http://www.turbobygarrett.com/turbob...o_tech102.html
Old Mar 7, 2006 | 09:47 PM
jtharvey's Avatar
jtharvey
Also, both the intake and exhaust housings have an AR ratio. Most of the time, we only talk about the exhaust housing's AR though. When I upgraded my turbo bits, I noticed that the stock compressor housing is a 1.0 A/R. Stock exhaust housing is a .84 A/R. That link that strokin provided has a lot of good info.
